treat set of files as a group
For technical support visit
Postby dave010 » Tue Aug 01, 2017 10:28 pm
i am still on version of syncbackpro and i would like to archive some old files created by drive imaging software.
the filenames use a format "guid-IncrementalNumber". u can guess that each differential image is saved by incrementing the number.
i can identify which "group" of files need moving say those with a guid where they are all created more than 6 months ago. but clearly i do not want to split the group - they should be treated together (based upon the share guid of the filename) - so a simple filter on date created cannot work.
i can create a profile to do this using filters to select only the image group to archive with: *\guid* as a filter.
is it possible to set the filter via the commandline or any other options that would allow me to point syncback to the groups that need moving?
thanks for your help.
Users browsing this forum: No registered users and 8 guests
