Options to speed up scan phase on large file couns with low % of changes
storagenetworking
Post by storagenetworking » Tue Aug 01, 2017 3:49 pm
I am in the process of tuning replication on Windows 2008 files shares
The source server has 5-6 TB of raw data and millions of files. It has Enterprise Vault file archiving enabled that converts everything older than 12 months into stabs.
My goal is to replicate this server with a daily sync schedule with Compare options "Less than 12 month" with Mirror replication settings
I was able to configure profiles for shares, do initial sync etc.
Now for deltas, the number of files to update across the whole server is in low thousands but the scan portion takes too long.
Majority of files are Enterprise Vault archive stabs but from OS perspective they cannot be identified by file attributes. I was hoping to be able to exclude them but cannot find an option to identify, except Enterprise Vault GUI itself.
Do you guys have any suggestions on what settings I can tweak to minimize the scan portion.
Re: Options to speed up scan phase on large file couns with low % of changes
Post by Swapna » Wed Aug 02, 2017 6:20 am
Can you please submit a support ticket to [email protected] with your profile configuration, and a Windows explorer screen shot showing those stub files (created by Enterprise Vault) for further assistance.
storagenetworking
Post by storagenetworking » Wed Aug 02, 2017 4:15 pm
Submitted, thx!
