Mirror not working as expected
Bassflute
Post by Bassflute » Wed Jul 26, 2017 7:36 pm
Hi Folks,
I have a recurring problem with my mirror to USB setup here.
I have set it up as a mirror from hard disk to USB and it runs periodically (e.g. on the hour). In this way, it offers security against a disk crash happening from one disk image to another (which runs nightly). Plus versioning gives me a bit of leeway if I accidentally trash a file.
What is odd is that SyncBack regularly "re-mirrors" whole swathes of files even though they haven't changed for months or years. I am currently waiting for just such a sync to finish as it is going through 180+ GB of files. This time, I also decided to look at what it is doing.
It is simply going into every directory, resetting the directory date and then deleting and copying over every individual file (with unchanged date).
If I look at the source directory on my hard disk, it says e.g. 1 August 2016 while the target directory on the USB disk now says 27 July 2017 (today's date).
This is absolutely counter-intuitive and also entirely wrong: I do NOT want different folder dates on my USB disk as this might well screw up any restore if I have no idea when the directory was created!
Is there some setting I have set that could be causing this or is this a bug?
My settings are pretty simple:
Code: Select all
Files will be mirrored from Source (T:\) to Destination (E:\KAPOK\SyncBackPro\).
If the same file has been changed on both Destination and Source then the file on Source will replace the file on Destination.
Files only on Destination are deleted.
Files only on Source are copied to Destination.
If an empty directory is only on Destination then the decision is automated.
If an empty directory is only on Source then the decision is automated.
The log file will be emailed after the profile has run (but only if the profile run fails).
The following files/folders will be ignored: *\$RECYCLE.BIN\,*\*.SBSECOR,"*\AppData\Local\Temporary Internet Files\",*\AppData\Local\Temp\,"*\Application Data\Mozilla\Firefox\Profiles\*\parent.lock",*\desktop.ini,*\DfsrPrivate\,"*\Local Settings\Temporary Internet Files\","*\Local Settings\Temp\","*\Microsoft\Windows\Temporary Internet Files\",*\RECYCLER\,*\SBSE____.*,"*\System Volume Information\",*\System32\Msdtc\MSDTC.LOG,*\thumbs.db,*\Windows\csc\,*\Windows\debug\NtFrs*,*\Windows\ntfrs\jet\,*\Windows\Prefetch\,*\Windows\Registration\*.crmlog,*\Windows\sysvol\domain\DO_NOT_REMOVE_NtFrs_PreInstall_Directory\,*\Windows\sysvol\domain\NtFrs_PreExisting___See_EventLog\,*\Windows\sysvol\staging\domain\NTFRS_*,*\Windows\Temp\,\#recycle*,\hiberfil.sys,\pagefile.sys,\PGPWDE01
The profile is stored in C:\Users\Bassflute\AppData\Local\2BrightSparks\SyncBackPro\
Re: Mirror not working as expected
Post by Swapna » Thu Jul 27, 2017 3:03 am
Please submit a support zip (with debug logs) of your profile configuration and a screen shot of the Differences Window pointing to an unchanged file for further investigation. Full instructions to create and submit a support zip are given here:
There is a non-default option in SyncBackPro to preserve the Created stamp for folders, which is under:
Modify profile > Expert mode > Copy/Delete > Folders > 'Copy sub-directory attributes and creation date (only when new directories are created)'
As stated in the help file, this option copies the creation date when new directories are created, but it can't update the creation date/ time stamps for already copied folders. This option must be in force before/at the time the new copy was created. However, there is no option to set the last modified date/time stamp of a folder, as it is controlled by Windows. Please read this forum post for additional details:
viewtopic.php?t=5593
