Feature request: DNS Lookup for IP Addreses
Currently in BETA
Postby hhh » Tue Nov 22, 2011 3:46 pm
At the moment it is only possible to specify which machines are allowed to connect to the server by entering their IP addresses.
Being able to also enter domain addresses for remote machines is of importance since the remote machines are often on dynamic IP addresses (and, therefore, on dynamic DNS names).
thanks in advance,
Henrik
hhh
Advanced
Advanced
Re: Feature request: DNS Lookup for IP Addreses
Postby mickyj » Wed Nov 23, 2011 1:31 am
Hi Henrik, thanks for your suggestion. We'll see if we can add this for the next release. Thanks.
Postby jsmply » Wed Nov 30, 2011 7:53 am
Agreed, this is definitely a needed feature.
jsmply
Postby hhh » Fri Feb 24, 2012 8:24 am
Any news on this feature?
We have a large amount of installations and would love to run SBM but without this feature it is not possible.
thanks
Henrik
hhh
Advanced
Advanced
Postby mickyj » Fri Feb 24, 2012 8:55 am
I've just uploaded a new beta (server & console) that includes this.
Postby hhh » Fri Feb 24, 2012 9:19 am
Excellent! Thanks!
hhh
Advanced
Advanced
Postby mickyj » Sat Feb 25, 2012 2:47 am
There was a mistake in the installation for this beta version.
On 64-bit versions of Windows it incorrectly installed to the 64-bit program files folder. We've uploaded new beta versions to fix this.
After installing the new beta versions (V1.4.1 and V2.1.1) you can delete the previous version manually from the following folders:
C:\Program Files\2BrightSparks\SBMService\
C:\Program Files\2BrightSparks\SBMConsole\
If you are using 32-bit Windows then there is no need to do this.
Return to SBM Service and Console
User Control Panel
Login
