Footer affecting new topic header
• Page 1 of 1
When I open a new topic I see a standard text showing the date and time. If I now select that I can overtype this and add new title to the document. That is until I turn on footers... When I do this then this seems to make this standard text behave differently and when I try and paste over it it now formats the text into a narrow table cell going down the page.
I'm sure I could find a way to turn of the default text for a new topic but my question is - why should having the footer on or off make a difference to the paste operation?
- matt586
I can't answer the question directly but would suggest you turn off the date/time stamp (Settings>Workspace preferences>Program options then uncheck "Enable Informational Stamp") because overtyping it might conceivably be linked to your problem.
I hope this helps - and am sorry it's not a direct answer to your question.
Stephen
Stephen
- Stephen_C
Hi Matty C,
We would be happy to investigate this issue further if you would like to
submit a support ticket at:
http://www.2brightsparks.com/help/index.php?pf=usr
There's an article that explains the support ticket sign-up process at:
http://www.2brightsparks.com/help/index ... article=15
Our online ticketing system ensures that support requests are logged and
tracked properly. A record is kept of each support request for both the
user and our staff to view. This results in more effective
communication, and a faster resolution to issues.
Thank you once again for your interest in our software
tituspaul - 2BrightSparks Staff
• Page 1 of 1
Return to InfoHesiveEP (freeware)
