The products do not follow Microsoft start menu guidelines
Do not post questions here! For reporting errors or missing information in help files, translations, documentation, etc. for all 2BrightSparks software and the web site.
Postby dwalker59 » Wed Sep 08, 2010 5:05 pm
Microsoft has guidelines on what a program, when installed, should put in the Start menu:
http://msdn.microsoft.com/en-us/library/aa511447.aspx
•Put only program shortcuts on the Start menu. Don't put shortcuts to the following items on the Start menu:
◦Program uninstallers. Users access uninstallers through the Programs control panel item.
◦Help files. Users access Help topics directly from your program.
◦Utility programs. Users access utilities from commands in the Tools menu.
◦Readme files. Reconsider the need for such files, because most users never look at them. If you do need a Readme file, let users access it from your setup program.
◦Web sites. Users access Web sites through appropriate links in your program, or Help for technical support sites.
... This page also says "Generally, your program should have a single shortcut on the Start menu."
The screenshots are geared toward Vista and Windows 7, but the advice applies equally well to Windows XP (which will be unsupported in about 3 years).
I like the Syncback products, and I would like to see the products follow the Microsoft guidelines in this area. Thanks.
dwalker59
Return to Help files, documentation, translations, etc.
User Control Panel
Login
