Error and other problems in the polish translation
Do not post questions here! For reporting errors or missing information in help files, translations, documentation, etc. for all 2BrightSparks software and the web site.
Postby Theodor » Sat Dec 13, 2008 10:37 pm
SyncBack SE V. 5.2.1.0
The polish translation is not really good. The biggest, annoying error in: "profile setup" - "the description of this profile" - in case of the synchronisation - second position:
there is: "nowszy plik bĂŞdzie zastÂąpiony przez starszy" (it means "the newer file will BE (!) replaced by the older file")
it should be: "starszy plik bĂŞdzie zastÂąpiony przez nowszy"
Then, the translation is not completed. It's a pity. The program is really good.
Theodor
Postby mickyj » Mon Dec 15, 2008 5:31 am
Hi, does that mean you are offering to complete/correct the Polish translation? :wink:
Postby Theodor » Mon Dec 15, 2008 7:01 am
I would like do it, but... perhaps in Summer 2009. Such a technical text from eng to pl - I could manage it. I've been using the SE Version for some months (intensively :) ), I know it quite good. But... the TIME...
Theodor
Return to Help files, documentation, translations, etc.
User Control Panel
Login
