New versions of OnClick software (March 2011)
1 post
• Page 1 of 1
New versions of all the OnClick software have been released. The most significant update is that DeleteOnClick and HashOnClick now work with 64-bit Windows:
DeleteOnClick V2.2.32.100
New: Now works on 64-bit Windows
EncryptOnClick V1.4.0.4
New: Can select multiple files to encrypt
Updated: No longer uses 3rd party controls for Unicode
FindOnClick V2.1.0.7
New: Option to use standard Windows search (via command line or search settings window)
Fixed: Drive letters W: and M: shown as ... in search window
Fixed: Folder disappears from search results when doing long right-click on it in search results
HashOnClick V2.2.32.21
New: Command line option to change output format (-altout)
PatchOnClick V2.3
New: Self-extracting patch file now accepts command line parameters (file to patch, file to create)
Updated: No dialog box prompts are displayed if run with command line parameters
ScrambleOnClick V1.1
UndeleteOnClick V1.6
PatchOnClick V2.3
mickyj - 2BrightSparks Staff
1 post
• Page 1 of 1
