Is there any way to search for JUST folders?
Postby David4321 » Fri Oct 16, 2009 10:25 pm
I know I can add the folder name to the path filter, but it there any way to limit search results to display folders only?
Also, I used "quotes", but I still got partial matches (of files and folders) - is there any way to limit results to exact matches only?
Thanks.
David4321
Postby Dave Wilkins » Fri Oct 16, 2009 11:25 pm
Hi
Q1) Attributes tab > 'Do not show files'
Q2) use single-quotes - as per the Help ("FindOnClick > Using FindOnClick > FindOnClick - Easy Search")
Search On Exact Filename
You can use single quotes to specify an exact filename. For example 'mynewdoc.txt' will limit the FindOnClick search to finding only those files that exactly match the file name mynewdoc.txt.
(PS: it may help on any future query if you specify which program you're asking about :) - OnClick Utilities incorporates 8 different programs... )
Dave Wilkins
Postby David4321 » Sat Oct 17, 2009 4:34 am
Thank You!
David4321
Return to OnClick Utilities
cron
User Control Panel
Login
