SyncBackPro V6.1.1.19 BETA available
1 post
• Page 1 of 1
Download the beta version here:
Changes in this beta:
New (Pro): Bandwidth throttling when using cloud
New: Special links in HTML log files to exclude files and folders and to modify the profile
Fixed (Pro): When uploading large files to S3 it may fail with error InvalidPartOrder
Fixed (Pro): May crash on start on some systems if there is invalid data in the registry for MIME types
Fixed (Pro): Unable to refresh bucket list if there was a bucket with an invalid name
Fixed (Pro): Now works with US buckets that did not follow the stricter naming rules
Fixed (Pro): Setting a files date and time or attributes on the cloud (without copying the file)
Fixed (Pro): Was not setting MD5 hash value in meta-data when uploading to cloud
Fixed (Pro): Long filenames when using cloud
Fixed: 'Drive not found' bug with some junction points when it is the base directory
Fixed: In some situations changes in folder case are not detected
Fixed: Silently fail if destination cannot be reached would cause profiles not to run if using cloud
Fixed: Windows handle leak when using compression
Fixed: Could get corrupt file and folder selections if chose skip and exclude from Differences window
Updated (Pro): Prompts for cloud username if it is wrong (when creating and modifying profiles)
Updated: In Differences window, when double-clicking an entry, will now open file/folder if there is nothing to compare with
Updated: Warning to clear history if switching compression on or off and using a SmartSync profile
Updated: The file and folder selection tree now correctly saves case changes for folders
Updated: On Vista and newer it now uses a more modern directory selection dialog
Updated: Small tweaks to installer and default scheduled task settings for Windows 8
Updated: All action prompt decisions must now be made before any copying or deleting is done
Updated: madExcept exception handler
Updated: Debug log now includes CPU usage
mickyj - 2BrightSparks Staff
1 post
• Page 1 of 1
