SyncBack Pro 6.1.0.5: Problem with Amazon S3
• Page 1 of 1
Since the installation of latest version of SyncBack Pro 6.1.0.5, I have some trouble with my backup jobs to Amazon S3. I get each time the following critical error while trying to transfer the archive file to Amazon S3:
loud error 400: HTTP/1.1 400 Bad Request - The list of parts was not in ascending order. Parts must be ordered by part number. (InvalidPartOrder)
What do the backup jobs ? Compress a large quantity of files (more than 50.000) into a zipx file of something like 4 GBytes, and put this zipx file to my Amazon S3 account.
What I don't understand is that my jobs worked without any problem with previous version 6.0.12.0...
Another clue: when I do a test with a few files only (some megabytes), it works without any problem too.
- PGombeer
Re: SyncBack Pro 6.1.0.5: Problem with Amazon S3
Hi
Yes, someone else reported that a couple of days ago (via Support Ticket). This beta should fix it
Do not uninstall / reinstall, or you'll lose your profiles & settings. Just install 'over the top'
- Dave Wilkins
OK, thanks for the follow-up. I will try this new version.
- PGombeer
Status report: this new version works with Amazon S3 without any problem. Thanks.
- PGombeer
• Page 1 of 1
