Transfer Multiple Files at once?
Postby robertfah » Tue May 08, 2012 4:02 pm
We are trying out SyncBack Pro and are trying to figure out how to have the program transfer more than 1 file at once. Can this be done, if so where do I change the settings?
Thanks!
robertfah
Re: Transfer Multiple Files at once?
Postby Dave Wilkins » Tue May 08, 2012 4:47 pm
Hi
Um, transfer to where, using what? ;)
If you mean via FTP, not currently, no. You can try this workaround, but you should take steps to ensure there is no overlap, otherwise they might try to copy the same file at the same time, and fight over it...
Dave Wilkins
User Control Panel
Login
