loss password - uninstall syncback
Postby jalex » Mon Apr 23, 2012 8:11 am
Help /
How to uninstall SyncBackSE? (PC Windows)
How to manage the loss of the pass word?
Comment déinstaller SyncbackSE ? ( sur PC windows)
Comment gérer la perte du mot de pass ?
Merci salutations
jalex
Re: loss password - uninstall syncback
Postby mickyj » Tue Apr 24, 2012 4:12 am
Hi, you can uninstall it the same way you uninstall any program in Windows, i.e. via "Uninstall a program" in the Windows Control Panel.
Also, which password are you referring to? There are many passwords in SyncBack, e.g. profile password, encryption password, etc.
Postby jalex » Tue Apr 24, 2012 8:44 am
Bonjour,
To change planning for "Tasks". We lost the pass.( profil password)
Error message:
"An error has occurred while attempting to set task account information.
specific error
0x8007052e: Failed opening sessions: word unknown user or password incorrect pass. "
It is impossible to uninstall SyncBack via "Control Panel” / Programs windows/ uninstal ...
It is impossibe to delete the folder SyncBack folder "Programs"
The error message:
"This action can not be completed because the folder and any file or open in another program"
How to erase everything and return to a clean install.
thank you greetings
To change and planning for "Tasks". We lost the pass.
Error message:
specific error
It is impossible to uninstall SyncBack via "Control Panel” / Programs windows.
The error message:
thank you greetings
Pour modifier la planification de « Tâches » Nous avons perdu le pass .
Message erreur :
« Une erreur s'est produite lors de la tentative de définition des informations du compte de tâche.
Erreur spécifique
0x8007052e : Echec d'ouverture de sessions : mot d'utilisateur inconnu ou mot de pass incorrect. »
IL est impossible de déinstaller Syncback via «Panneau de configuration / Programmes de windows.
Il est impossibe de supprimer le dossier Syncback du dossier « Programmes »
le message d'erreur :
« Cette action ne peut être réalisée car le dossier et ou l'un des fichiers est ouvert dans un autre programme »
Comment faire pour tout effacer et reprendre une installation propre.
jalex
Postby mickyj » Tue Apr 24, 2012 8:56 am
Hi, the error (0x8007052e) is from Windows saying that your login password (for the schedule) is wrong. That is your Windows login password. It's not a password stored in SyncBack. It's the password you've set the task in the Windows Task Scheduler to use. Uninstalling won't fix this. You need to set the correct password or delete the tasks.
There are two ways to solve the uninstall if it's still running:
- Reboot Windows into Safe Mode and uninstall
- Run the Task Manager and kill the SyncBack.exe process then uninstall
Users browsing this forum: Google [Bot] and 4 guests
User Control Panel
Login
In total there are 5 users online :: 1 registered, 0 hidden and 4 guests (based on users active over the past 5 minutes)
