Configuration Issue !
Postby comip » Mon Mar 19, 2012 2:00 pm
I'm using SyncBack very recently to backup files to a FTP and i'm having an issue to configure the order of the synchronisation...
Let me explain it :
At 10AM I paste Fic1,Fic2,Fic3,Fic4,Fic5 in the folder which is synchronised automatically .
What i want to do is to synchronise Fic5 at the first and then Fic4 and then Fic3 etc...
I'v also another question, During this process, if i paste another file Fic6 while Fic3 is transfering, can we make Fic6 synchronised at first and then continue the previous ordre (which means Fic2 and Fic1)
Hope I was was clear and that someone who can help me !
comip
Re: Configuration Issue !
Postby Dave Wilkins » Mon Mar 19, 2012 3:04 pm
There are no functions to sort the order of processing in any version of our software. Folders/files are processed strictly in the order they are encountered during folder recursion during the scan.
Dave Wilkins
Postby comip » Mon Mar 19, 2012 3:25 pm
That means, if I put in order Fic1,Fic2,Fic3,Fic4,Fic5 while the FTP is offline, when the FTP mounts up, It will first send Fic1 then Fic2,Fic3,Fic4,Fic5 ?
comip
Postby Dave Wilkins » Mon Mar 19, 2012 3:47 pm
No idea, sorry. It depends in what order your system lists the files.
Dave Wilkins
Postby comip » Tue Mar 27, 2012 2:36 pm
Thanks for the reply,
There is any way to configure the system to order files from the LastModifiedDate at first as default ?
comip
Postby Dave Wilkins » Tue Mar 27, 2012 2:48 pm
Dave Wilkins wrote:There are no functions to sort the order of processing in any version of our software. Folders/files are processed strictly in the order they are encountered during folder recursion during the scan.
Dave Wilkins
Postby Dave Wilkins » Tue Mar 27, 2012 2:51 pm
Sorry, just realised what you were asking. Probably not. But that's nothing to do with configuring our software anyway.
Dave Wilkins
Postby comip » Tue Mar 27, 2012 3:08 pm
Actually what I need is to send the last modified files at first to the FTP so i want to know if its possible in Freeware or purchase version or no version, because it's what i need and it's the only thing I need.
Thank you,
comip
Postby Dave Wilkins » Tue Mar 27, 2012 3:46 pm
Which gets us neatly back to
Dave Wilkins
Users browsing this forum: Google [Bot] and 1 guest
User Control Panel
Login
In total there are 2 users online :: 1 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
