Write of address 00000000C
Postby mickyj » Mon Jan 17, 2005 8:24 am
If you receive an error message like this (it may be at a different address than the one shown here):
Unexpected error has occurred:Access violation at address 005957f1 in module "SyncBack.exe. Write of address 00000000C
then it is very likely that your Zip file is greater than 2GB in size. SyncBackSE V4 has no Zip file size limitation, but the freeware version uses a different (and older) compression engine with this limitation. The solution is to either upgrade to SE V4 or break up your profile into two or more profiles (each backing up different directories) and run them in a group.
cron
User Control Panel
Login
In total there are 4 users online :: 0 registered, 0 hidden and 4 guests (based on users active over the past 5 minutes)
