Huge ZIp file support
Postby graham » Thu Apr 15, 2004 9:32 am
I see that Winzip 9 now has huge file support (>2Gb & > 65535 files). Is the technology proprietory - or could it be included in Syncback?. If it could - are there any plans to do so?
Thx
Graham
graham
Postby mickyj » Thu Apr 15, 2004 10:06 am
SyncBack uses the free Abbrevia library for compression. Once that supports it, then SyncBack will. I believe the maintainer of Abbrevia is going to include this. I don't have a timeframe for it yet though. Thanks.
User Control Panel
Login
